[postgis-tickets] r14336 - Set edge endpoints as isolated on ST_RemoveIsoEdge
Sandro Santilli strk at keybit.net
Thu Oct 29 01:37:37 PDT 2015
Author: strk
Date: 2015-10-29 01:37:37 -0700 (Thu, 29 Oct 2015)
New Revision: 14336
   branches/2.1/NEWS
   branches/2.1/topology/sql/sqlmm.sql.in
   branches/2.1/topology/test/regress/sqlmm.sql
   branches/2.1/topology/test/regress/sqlmm_expected
See #3351
Modified: branches/2.1/NEWS
--- branches/2.1/NEWS	2015-10-29 08:36:59 UTC (rev 14335)
+++ branches/2.1/NEWS	2015-10-29 08:37:37 UTC (rev 14336)
@@ -3,6 +3,7 @@
  * Bug Fixes *
+  - #3351, set endnodes isolation on ST_RemoveIsoEdge
   - #3198, ST_AddEdgeModFace docs report wrong side of new face
   - #3196, do not let DropTopology drop non-topology schemes
   - #3222, Fix uninitialized stddev in stats computation
Modified: branches/2.1/topology/sql/sqlmm.sql.in
--- branches/2.1/topology/sql/sqlmm.sql.in	2015-10-29 08:36:59 UTC (rev 14335)
+++ branches/2.1/topology/sql/sqlmm.sql.in	2015-10-29 08:37:37 UTC (rev 14336)
@@ -1767,7 +1767,7 @@
   END IF;
-  -- Check node existance
+  -- Check edge existance
   ok = false;
   FOR edge IN EXECUTE 'SELECT * FROM '
@@ -1782,7 +1782,7 @@
   END IF;
-  -- Check node isolation
+  -- Check edge isolation
   IF edge.left_face != edge.right_face THEN
     RAISE EXCEPTION
@@ -1808,7 +1808,16 @@
   EXECUTE 'DELETE FROM ' || quote_ident(atopology) || '.edge_data '
     || ' WHERE edge_id = ' || anedge;
+  -- Set endnodes isolated
+  EXECUTE 'UPDATE ' || quote_ident(atopology) || '.node '
+    || ' SET containing_face = ' || edge.left_face
+    || ' WHERE node_id in ( '
+    || edge.start_node || ',' || edge.end_node || ')';
   RETURN 'Isolated edge ' || anedge || ' removed';
 END
 LANGUAGE 'plpgsql' VOLATILE;
Modified: branches/2.1/topology/test/regress/sqlmm.sql
--- branches/2.1/topology/test/regress/sqlmm.sql	2015-10-29 08:36:59 UTC (rev 14335)
+++ branches/2.1/topology/test/regress/sqlmm.sql	2015-10-29 08:37:37 UTC (rev 14336)
@@ -135,7 +135,26 @@
 SELECT '-- ST_RemoveIsoEdge ---------------------';
+CREATE TEMP TABLE edge1_endnodes AS
+  WITH edge AS (
+    SELECT start_node,end_node
+    FROM sqlmm_topology.edge_data
+    WHERE edge_id = 1
+  SELECT start_node id FROM edge UNION
+  SELECT end_node FROM edge;
+SELECT '#3351.1', node_id, containing_face
+ FROM sqlmm_topology.node where node_id in (
+    SELECT id FROM edge1_endnodes
+ ORDER BY node_id;
 SELECT topology.ST_RemoveIsoEdge('sqlmm_topology', 1);
+SELECT '#3351.2', node_id, containing_face
+ ORDER BY node_id;
+DROP TABLE edge1_endnodes;
 -- ST_NewEdgesSplit
Modified: branches/2.1/topology/test/regress/sqlmm_expected
--- branches/2.1/topology/test/regress/sqlmm_expected	2015-10-29 08:36:59 UTC (rev 14335)
+++ branches/2.1/topology/test/regress/sqlmm_expected	2015-10-29 08:37:37 UTC (rev 14336)
@@ -47,7 +47,11 @@
 Isolated Node 8 moved to location 7,11
 Isolated Node 8 moved to location 7,10
+#3351.1|4|
+#3351.1|5|
 Isolated edge 1 removed
+#3351.2|4|0
+#3351.2|5|0
 -- ST_NewEdgesSplit  ---------------------
 9
 Topology 'sqlmm_topology' dropped
