[postgis-tickets] [PostGIS] #3271: WARNING: problem in alloc set ExprContext: detected write past chunk end in block 0000000004E0C9F0, chunk 0000000004E0DA80
trac at osgeo.org
Thu Sep 3 02:45:04 PDT 2015
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.2.0
Component: pagc_address_parser | Version: trunk
Keywords: |
This warning only seems to show if I'm testing under mingw64 (presumably
because I have that PostgreSQL compiled with cassert)
This I noticed when running the parse_address regression test:
copy test_parse_address (instring, outstring) from stdin;
select id, instring, outstring as expected, parse_address(instring) as
got_result
from test_parse_address
where instring not like '@@%' and parse_address(instring)::text !=
outstring;
I usually test against VC++ build so it's possible this has been there for
a while and I missed it or I introduced it when I made a change to
parse_address at r13992
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3271>
