[postgis-tickets] [PostGIS] #3271: WARNING: problem in alloc set ExprContext: detected write past chunk end in block 0000000004E0C9F0, chunk 0000000004E0DA80
trac at osgeo.org
Tue Sep 8 11:11:44 PDT 2015
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.2.0
Component: pagc_address_parser | Version: trunk
Resolution: worksforme | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => worksforme
Comment:
Okay not sure why happened here. I'm not getting the error anymore when
testings with my mingw64 install. Might be my playing around with
parse_address I introduced something that I later cleared out when I
repulled the file.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3271#comment:1>
