[postgis-tickets] [PostGIS] #3296: Add an install from unpackaged test
trac at osgeo.org
Mon Sep 28 00:16:43 PDT 2015
Reporter: robe | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: postgis | Version: 2.1.x
Resolution: | Keywords:
Comment (by strk):
It could be a special handling for "unpackaged" as a "from" version in the
--upgrade-path switch of run_test.pl. Right now using that label fails,
anyway:
./run_test.pl -v --extension --upgrade-path unpackaged--2.2.0dev
tickets.sql
ERROR: could not stat file
"/home/postgresql-9.3.4/share/extension/postgis--unpackaged.sql": No such
file or directory
Note this would still require installing the code first.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3296#comment:1>
