[postgis-tickets] [PostGIS] #3296: Add an install from unpackaged test
trac at osgeo.org
Mon Sep 28 00:20:37 PDT 2015
Reporter: robe | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: postgis | Version: 2.1.x
Resolution: | Keywords:
Comment (by strk):
Actually, I'm thinking there might be a problem with using --upgrade-path
in that the "unpackaged" label for the "from" component would not be able
to express _which_ version of unpackaged to load from. Should maybe be
"unpackaged:version" or something like that. Besides, the CREATE EXTENSION
command itself doesn't distinguish between versions of "unpackaged", which
may be a source of confusion already (think someone creating extension
postgis version 2.2.0 from unpackaged version 1.5.0...)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3296#comment:2>
