[postgis-tickets] [PostGIS] #3518: PostgreSQL 9.5.2 windows (EDB) incompatible with PostGIS 2.2.2 binaries
PostGIS trac at osgeo.org
Fri Apr 1 22:56:38 PDT 2016
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 2.2.3
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:                         |   Keywords:  windows
Comment (by robe):
 Confirmed - replacing libcurl-4.dll I distribute with a non-ssl one (so no
 reliance on these libraries works).  I'll rebuild libcurl-4.dll with newer
 libs, but I suspect if that fixes 9.5.2 it will break 9.5.1 (and previous
 patch).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3518#comment:3>
