[postgis-tickets] [PostGIS] #3521: Wrong result of <select distinct geometry from XXX>
trac at osgeo.org
Wed Apr 6 22:16:48 PDT 2016
Reporter: yuanrui1987 | Owner: pramsey
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 2.2.2
Component: postgis | Version: 1.5.X
Resolution: invalid | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => invalid
* milestone: => PostGIS 2.2.2
Comment:
This is not a bug, but by design. When you use DISTINCT it uses the =
operator which is tied to bounding box equality not geometry equality.
You could group by or distinct on geom::text to get what you want.
Anyrate please ask for help on our mailing list, not our bug tracker.
https://lists.osgeo.org/mailman/listinfo/postgis-users
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3521#comment:1>
