[postgis-tickets] r14840 - #3529, move test to subdivide.sql
Paul Ramsey
pramsey at cleverelephant.ca
Wed Apr 13 09:53:11 PDT 2016
Author: pramsey
Date: 2016-04-13 09:53:11 -0700 (Wed, 13 Apr 2016)
New Revision: 14840
branches/2.2/regress/subdivide.sql
branches/2.2/regress/subdivide_expected
branches/2.2/regress/tickets.sql
Modified: branches/2.2/regress/subdivide.sql
--- branches/2.2/regress/subdivide.sql 2016-04-13 16:53:02 UTC (rev 14839)
+++ branches/2.2/regress/subdivide.sql 2016-04-13 16:53:11 UTC (rev 14840)
@@ -22,3 +22,5 @@
SELECT '3' As rn, full_area::numeric(10,3) = SUM(ST_Area(gs.geom))::numeric(10,3), COUNT(gs.geom) As num_pieces, MAX(ST_NPoints(gs.geom)) As max_vert
FROM gs
GROUP BY gs.full_area;
+SELECT '#3522', ST_AsText(ST_Subdivide(ST_GeomFromText('POINT(1 1)',4326),10));
Modified: branches/2.2/regress/subdivide_expected
--- branches/2.2/regress/subdivide_expected 2016-04-13 16:53:02 UTC (rev 14839)
+++ branches/2.2/regress/subdivide_expected 2016-04-13 16:53:11 UTC (rev 14840)
@@ -1,3 +1,4 @@
1|t|9|9
2|t|6|7
3|t|15|9
+#3522|POINT(1 1)
Modified: branches/2.2/regress/tickets.sql
--- branches/2.2/regress/tickets.sql 2016-04-13 16:53:02 UTC (rev 14839)
+++ branches/2.2/regress/tickets.sql 2016-04-13 16:53:11 UTC (rev 14840)
@@ -933,8 +933,5 @@
UNION ALL
SELECT '#3437e' AS t, count(*) FROM mp INNER JOIN p ON ST_Within(p.geom, mp.geom);
--- GEOS 3.5+ only
--- SELECT '#3522', ST_AsText(ST_Subdivide(ST_GeomFromText('POINT(1 1)',4326),10));
-- Clean up
DELETE FROM spatial_ref_sys;
