[postgis-tickets] r14848 - Minor cleanup, change to schema qualify tables,
Regina Obe lr at pcorp.us
Sun Apr 17 13:38:14 PDT 2016
Author: robe
Date: 2016-04-17 13:38:14 -0700 (Sun, 17 Apr 2016)
New Revision: 14848
   branches/2.2/extras/tiger_geocoder/geocode/geocode_intersection.sql
change to use tiger node ids overlap instead of intersects for determining intersections
Closes #3530 for PostGIS 2.2.3
References #3451
Modified: branches/2.2/extras/tiger_geocoder/geocode/geocode_intersection.sql
--- branches/2.2/extras/tiger_geocoder/geocode/geocode_intersection.sql	2016-04-17 20:30:29 UTC (rev 14847)
+++ branches/2.2/extras/tiger_geocoder/geocode/geocode_intersection.sql	2016-04-17 20:38:14 UTC (rev 14848)
@@ -1,6 +1,6 @@
- * Copyright (C) 2011 Regina Obe and Leo Hsu (Paragon Corporation)
+ * Copyright (C) 2011-2016 Regina Obe and Leo Hsu (Paragon Corporation)
 -- This function given two roadways, state and optional city, zip
 -- Will return addresses that are at the intersecton of those roadways
@@ -8,10 +8,17 @@
 -- Use case example an address at the intersection of 2 streets:
 -- SELECT pprint_addy(addy), st_astext(geomout),rating FROM geocode_intersection('School St', 'Washington St', 'MA', 'Boston','02117');
 --DROP FUNCTION tiger.geocode_intersection(text,text,text,text,text,integer);
-CREATE OR REPLACE FUNCTION geocode_intersection(IN roadway1 text, IN roadway2 text, IN in_state text, IN in_city text DEFAULT '', IN in_zip text DEFAULT '',
-IN num_results integer DEFAULT 10,  OUT ADDY NORM_ADDY,
-    OUT GEOMOUT GEOMETRY,
-    OUT RATING INTEGER) RETURNS SETOF record AS
+CREATE OR REPLACE FUNCTION geocode_intersection(
+    IN roadway1 text,
+    IN roadway2 text,
+    IN in_state text,
+    IN in_city text DEFAULT ''::text,
+    IN in_zip text DEFAULT ''::text,
+    IN num_results integer DEFAULT 10,
+    OUT addy norm_addy,
+    OUT geomout geometry,
+    OUT rating integer)
+  RETURNS SETOF record AS
 DECLARE
     var_na_road norm_addy;
@@ -48,19 +55,19 @@
     var_sql := '
     WITH
     	a1 AS (SELECT f.*, addr.fromhn, addr.tohn, addr.side , addr.zip
-    				FROM (SELECT * FROM featnames
+    				FROM (SELECT * FROM tiger.featnames
     							WHERE statefp = $1 AND ( lower(name) = $2  ' ||
     							CASE WHEN length(var_na_road.streetName) > 5 THEN ' or  lower(fullname) LIKE $6 || ''%'' ' ELSE '' END || ')'
-    							|| ')  AS f LEFT JOIN (SELECT * FROM addr WHERE addr.statefp = $1) As addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
+    							|| ')  AS f LEFT JOIN (SELECT * FROM tiger.addr As addr WHERE addr.statefp = $1) As addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
     					WHERE $5::text[] IS NULL OR addr.zip = ANY($5::text[]) OR addr.zip IS NULL
     				ORDER BY CASE WHEN lower(f.fullname) = $6 THEN 0 ELSE 1 END
     				LIMIT 50000
         a2 AS (SELECT f.*, addr.fromhn, addr.tohn, addr.side , addr.zip
     							WHERE statefp = $1 AND ( lower(name) = $4 ' ||
     							CASE WHEN length(var_na_inter1.streetName) > 5 THEN ' or lower(fullname) LIKE $7 || ''%'' ' ELSE '' END || ')'
-    							|| ' )  AS f LEFT JOIN (SELECT * FROM addr WHERE addr.statefp = $1) AS addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
+    							|| ' )  AS f LEFT JOIN (SELECT * FROM tiger.addr As addr WHERE addr.statefp = $1) AS addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
     					WHERE $5::text[] IS NULL OR addr.zip = ANY($5::text[])  or addr.zip IS NULL
     			ORDER BY CASE WHEN lower(f.fullname) = $7 THEN 0 ELSE 1 END
     				LIMIT 50000
@@ -68,14 +75,14 @@
     	 e1 AS (SELECT e.the_geom, e.tnidf, e.tnidt, a.*,
     	 			CASE WHEN a.side = ''L'' THEN e.tfidl ELSE e.tfidr END AS tfid
     	 			FROM a1 As a
-    					INNER JOIN  edges AS e ON (e.statefp = a.statefp AND a.tlid = e.tlid)
+    					INNER JOIN  tiger.edges AS e ON (e.statefp = a.statefp AND a.tlid = e.tlid)
     				WHERE e.statefp = $1
     				ORDER BY CASE WHEN lower(a.name) = $4 THEN 0 ELSE 1 END + CASE WHEN lower(e.fullname) = $7 THEN 0 ELSE 1 END
     				LIMIT 5000) ,
     	e2 AS (SELECT e.the_geom, e.tnidf, e.tnidt, a.*,
-    				FROM (SELECT * FROM edges WHERE statefp = $1) AS e INNER JOIN a2 AS a ON (e.statefp = a.statefp AND a.tlid = e.tlid)
-    					INNER JOIN e1 ON (e.statefp = e1.statefp AND ST_Intersects(e.the_geom, e1.the_geom)
+    				FROM (SELECT * FROM tiger.edges WHERE statefp = $1) AS e INNER JOIN a2 AS a ON (e.statefp = a.statefp AND a.tlid = e.tlid)
+    					INNER JOIN e1 ON (e.statefp = e1.statefp
     					AND ARRAY[e.tnidf, e.tnidt] && ARRAY[e1.tnidf, e1.tnidt] )
     				WHERE (lower(e.fullname) = $7 or lower(a.name) LIKE $4 || ''%'')
@@ -100,9 +107,9 @@
                                 AS a_rating
                     FROM e1
                             INNER JOIN e2 ON (
-                                    ST_Intersects(e1.the_geom, e2.the_geom)  )
-                             INNER JOIN (SELECT * FROM faces WHERE statefp = $1) As fa1 ON (e1.tfid = fa1.tfid  )
-                          LEFT JOIN place AS p ON (fa1.placefp = p.placefp AND p.statefp = $1 )
+                                  ARRAY[e2.tnidf, e2.tnidt] && ARRAY[e1.tnidf, e1.tnidt]  )
+                             INNER JOIN (SELECT * FROM tiger.faces WHERE statefp = $1) As fa1 ON (e1.tfid = fa1.tfid  )
+                          LEFT JOIN tiger.place AS p ON (fa1.placefp = p.placefp AND p.statefp = $1 )
                        ORDER BY e1.tlid, e1.side, a_rating LIMIT $9*4 )
     SELECT address, fedirp , fename, fetype,fedirs,place, zip , geom, a_rating
         FROM segs ORDER BY a_rating LIMIT  $9';
@@ -145,4 +152,4 @@
   LANGUAGE plpgsql IMMUTABLE
   COST 1000
   ROWS 10;
-ALTER FUNCTION geocode_intersection(IN text, IN text, IN text, IN text, IN text, IN integer) SET join_collapse_limit='2';
+ALTER FUNCTION geocode_intersection(text, text, text, text, text, integer) SET join_collapse_limit='2';
