[postgis-tickets] [PostGIS] #2734: TIGER geocoder geocode_intersection gives no results with omitted zipcode
PostGIS trac at osgeo.org
Sun Apr 17 14:26:37 PDT 2016
  Reporter:  futuraprime     |      Owner:  robe
      Type:  defect          |     Status:  closed
  Priority:  high            |  Milestone:  PostGIS 2.2.0
 Component:  tiger geocoder  |    Version:  2.1.x
Resolution:  fixed           |   Keywords:
Changes (by robe):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 this is a different problem - will log as separate ticket.  Has to do with
 some address numbers not being numbers so need to be cast to number so can
 fit in norm_addy.  I thnk my change just resulted in a couple of more
 matches (which are correct) but are not numbers.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2734#comment:11>
