[postgis-tickets] [PostGIS] #3531: geocode_intersection and geocode error on none-address numbers
PostGIS trac at osgeo.org
Sun Apr 17 14:29:58 PDT 2016
 Reporter:  robe            |      Owner:  robe
     Type:  defect          |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS 2.2.3
Component:  tiger geocoder  |    Version:  2.2.x
 Keywords:                  |
 Case in point:
 SELECT pprint_addy(addy), st_astext(geomout), rating FROM
   geocode_intersection('Broadway', 'Houston St', 'NY', 'New York',
 '10012');
 because one of the solutions has address number 612-100.
 But norm_addy -- address field is an integer.
 For now I'm just going to revise to return the first part that is an
 integer. - which would be 612 for this case.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3531>
