[postgis-tickets] r14856 - #3424, ST_MinimumClearance
    Daniel Baston
    dbaston at gmail.com
    Mon Apr 25 14:02:24 PDT 2016
Author: dbaston
Date: 2016-04-25 14:02:23 -0700 (Mon, 25 Apr 2016)
New Revision: 14856
   trunk/NEWS
   trunk/doc/introduction.xml
   trunk/doc/reference_measure.xml
   trunk/postgis/lwgeom_geos.c
   trunk/postgis/postgis.sql.in
   trunk/regress/Makefile.in
Modified: trunk/NEWS
--- trunk/NEWS	2016-04-22 09:46:38 UTC (rev 14855)
+++ trunk/NEWS	2016-04-25 21:02:23 UTC (rev 14856)
@@ -16,6 +16,7 @@
   - #3339 ST_GeneratePoints (Paul Ramsey)
   - #3362 ST_ClusterDBSCAN (Dan Baston)
   - #3364 ST_GeometricMedian (Dan Baston)
+  - #3424 ST_MinimumClearance (Dan Baston)
   - #3428 ST_Points (Dan Baston)
   - #3465 ST_ClusterKMeans (Paul Ramsey)
   - #3469 ST_MakeLine with MULTIPOINTs (Paul Norman)
Modified: trunk/doc/introduction.xml
--- trunk/doc/introduction.xml	2016-04-22 09:46:38 UTC (rev 14855)
+++ trunk/doc/introduction.xml	2016-04-25 21:02:23 UTC (rev 14856)
@@ -264,6 +264,7 @@
 Lidwala Consulting Engineers,
 LisaSoft,
 Logical Tracking & Tracing International AG,
+Maponics,
 Michigan Tech Research Institute,
 Natural Resources Canada,
 Norwegian Forest and Landscape Institute,
Modified: trunk/doc/reference_measure.xml
--- trunk/doc/reference_measure.xml	2016-04-22 09:46:38 UTC (rev 14855)
+++ trunk/doc/reference_measure.xml	2016-04-25 21:02:23 UTC (rev 14856)
@@ -2361,6 +2361,133 @@
 	  </refsection>
 	</refentry>
+	<refentry id="ST_MinimumClearance">
+		<refnamediv>
+			<refname>ST_MinimumClearance</refname>
+			<refpurpose>Returns the minimum clearance of a geometry, a measure a geometry's robustness.</refpurpose>
+		</refnamediv>
+		<refsynopsisdiv>
+			<funcsynopsis>
+				<funcprototype>
+					<funcdef>float <function>ST_MinimumClearance</function></funcdef>
+					<paramdef><type>geometry </type><parameter>g</parameter></paramdef>
+				</funcprototype>
+			</funcsynopsis>
+		</refsynopsisdiv>
+	  <refsection>
+		<title>Description</title>
+		<para>
+			It is not uncommon to have a geometry that, while meeting the criteria for validity according to ST_IsValid (polygons)
+			or ST_IsSimple (lines), would become invalid if one of the vertices moved by a slight distance, as can happen during
+			conversion to text-based formats (such as WKT, KML, GML GeoJSON), or binary formats that do not use double-precision
+			floating point coordinates (MapInfo TAB).
+		</para>
+		<para>
+			A geometry's "minimum clearance" is the smallest distance by which a vertex of the geometry could be moved to produce
+			an invalid geometry.  It can be thought of as a quantitative measure of a geometry's robustness, where increasing values
+			of minimum clearance indicate increasing robustness.
+		</para>
+		<para>
+			If a geometry has a minimum clearance of <varname>e</varname>, it can be said that:
+			<itemizedlist>
+				<listitem>
+					<para>
+						No two distinct vertices in the geometry are separated by less than <varname>e</varname>.
+					</para>
+				</listitem>
+				<listitem>
+					<para>
+						No vertex is closer than <varname>e</varname> to a line segement of which it is not an endpoint.
+					</para>
+				</listitem>
+			</itemizedlist>
+		</para>
+		<para>
+			If no minimum clearance exists for a geometry (for example, a single point, or a multipoint whose points are identical), then
+			ST_MinimumClearance will return Infinity.
+		</para>
+		<para>Availability: 2.3.0 - requires GEOS >= 3.6.0</para>
+	  </refsection>
+	  <refsection>
+		<title>Examples</title>
+		<programlisting>
+SELECT ST_MinimumClearance('POLYGON ((0 0, 1 0, 1 1, 0.5 3.2e-4, 0 0))');
+ st_minimumclearance
+             0.00032
+     </programlisting>
+	  </refsection>
+	  <refsection>
+		<title>See Also</title>
+		<para>
+			<xref linkend="ST_MinimumClearanceLine" />
+		</para>
+	  </refsection>
+	</refentry>
+	<refentry id="ST_MinimumClearanceLine">
+		<refnamediv>
+			<refname>ST_MinimumClearanceLine</refname>
+			<refpurpose>Returns the two-point LineString spanning a geometry's minimum clearance.</refpurpose>
+		</refnamediv>
+	  <refsynopsisdiv>
+		<funcsynopsis>
+		  <funcprototype>
+			<funcdef>Geometry <function>ST_MinimumClearanceLine</function></funcdef>
+			<parameter>g</parameter></paramdef>
+		  </funcprototype>
+		</funcsynopsis>
+	  </refsynopsisdiv>
+	  <refsection>
+		<para>
+			Returns the two-point LineString spanning a geometry's minimum clearance.  If the geometry does not have a minimum
+			clearance, <varname>LINESTRING EMPTY</varname> will be returned.
+		</para>
+	  </refsection>
+	  <refsection>
+		  <programlisting>
+SELECT ST_AsText(ST_MinimumClearanceLine('POLYGON ((0 0, 1 0, 1 1, 0.5 3.2e-4, 0 0))'));
+st_astext
+LINESTRING(0.5 0.00032,0.5 0)
+		  </programlisting>
+	  </refsection>
+	  <refsection>
+		<para>
+			<xref linkend="ST_MinimumClearance" />
+		</para>
+	  </refsection>
+	</refentry>
 	<refentry id="ST_HausdorffDistance">
 	  <refnamediv>
 		<refname>ST_HausdorffDistance</refname>
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c	2016-04-22 09:46:38 UTC (rev 14855)
+++ trunk/postgis/lwgeom_geos.c	2016-04-25 21:02:23 UTC (rev 14856)
@@ -3662,3 +3662,98 @@
 #endif /* POSTGIS_GEOS_VERSION >= 35 */
+ * ST_MinimumClearance
+ * Returns the minimum clearance of a geometry.
+Datum ST_MinimumClearance(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(ST_MinimumClearance);
+#if POSTGIS_GEOS_VERSION < 36
+	lwpgerror("The GEOS version this PostGIS binary "
+	        "was compiled against (%d) doesn't support "
+	        "'ST_MinimumClearance' function (3.6.0+ required)",
+	        POSTGIS_GEOS_VERSION);
+	PG_RETURN_NULL();
+#else /* POSTGIS_GEOS_VERSION >= 36 */
+	GSERIALIZED* input;
+	GEOSGeometry* input_geos;
+	int error;
+	double result;
+	initGEOS(lwpgnotice, lwgeom_geos_error);
+	input = PG_GETARG_GSERIALIZED_P(0);
+	input_geos = POSTGIS2GEOS(input);
+	if (!input_geos)   /* exception thrown at construction */
+		HANDLE_GEOS_ERROR("Geometry could not be converted to GEOS");
+		PG_RETURN_NULL();
+	error = GEOSMinimumClearance(input_geos, &result);
+	GEOSGeom_destroy(input_geos);
+	if (error)
+		HANDLE_GEOS_ERROR("Error computing minimum clearance");
+		PG_RETURN_NULL();
+	PG_FREE_IF_COPY(input, 0);
+	PG_RETURN_FLOAT8(result);
+#endif
+ * ST_MinimumClearanceLine
+ * Returns the minimum clearance line of a geometry.
+Datum ST_MinimumClearanceLine(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(ST_MinimumClearanceLine);
+	        "'ST_MinimumClearanceLine' function (3.6.0+ required)",
+	PG_RETURN_NULL();
+	GSERIALIZED* result;
+	GEOSGeometry* result_geos;
+		PG_RETURN_NULL();
+	result_geos = GEOSMinimumClearanceLine(input_geos);
+	if (!result_geos)
+		PG_RETURN_NULL();
+	result = GEOS2POSTGIS(result_geos, LW_FALSE);
+	GEOSGeom_destroy(result_geos);
+	PG_RETURN_POINTER(result);
+#endif
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2016-04-22 09:46:38 UTC (rev 14855)
+++ trunk/postgis/postgis.sql.in	2016-04-25 21:02:23 UTC (rev 14856)
@@ -4001,6 +4001,18 @@
 	LANGUAGE 'c' IMMUTABLE STRICT
 	COST 100;
+-- Availability: 2.3.0
+CREATE OR REPLACE FUNCTION ST_MinimumClearance(geometry)
+	RETURNS float8
+	AS 'MODULE_PATHNAME', 'ST_MinimumClearance'
+	LANGUAGE 'c' IMMUTABLE STRICT;
+CREATE OR REPLACE FUNCTION ST_MinimumClearanceLine(geometry)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'ST_MinimumClearanceLine'
 -- PostGIS equivalent function: Centroid(geometry)
 CREATE OR REPLACE FUNCTION ST_Centroid(geometry)
 	RETURNS geometry
Modified: trunk/regress/Makefile.in
--- trunk/regress/Makefile.in	2016-04-22 09:46:38 UTC (rev 14855)
+++ trunk/regress/Makefile.in	2016-04-25 21:02:23 UTC (rev 14856)
@@ -216,6 +216,12 @@
 		voronoi
 endif
+ifeq ($(shell expr $(POSTGIS_GEOS_VERSION) ">=" 36),1)
+	# GEOS-3.6 adds:
+	# ST_MinimumClearance
+	TESTS += \
+		minimum_clearance
+endif
 ifeq ($(HAVE_JSON),yes)
 	# JSON-C adds:
