[postgis-tickets] r14860 - #3413, typo in find_srid error notice
Daniel Baston
dbaston at gmail.com
Tue Apr 26 17:06:35 PDT 2016
Author: dbaston
Date: 2016-04-26 17:06:35 -0700 (Tue, 26 Apr 2016)
New Revision: 14860
trunk/postgis/postgis.sql.in
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2016-04-26 23:19:09 UTC (rev 14859)
+++ trunk/postgis/postgis.sql.in 2016-04-27 00:06:35 UTC (rev 14860)
@@ -2654,7 +2654,7 @@
select SRID into sr from geometry_columns where (f_table_schema = schem or schem = '') and f_table_name = tabl and f_geometry_column = $3;
IF NOT FOUND THEN
- RAISE EXCEPTION 'find_srid() - couldnt find the corresponding SRID - is the geometry registered in the GEOMETRY_COLUMNS table? Is there an uppercase/lowercase missmatch?';
+ RAISE EXCEPTION 'find_srid() - could not find the corresponding SRID - is the geometry registered in the GEOMETRY_COLUMNS table? Is there an uppercase/lowercase mismatch?';
END IF;
return sr;
END;
