[postgis-tickets] r14862 - #3217, ST_Value documentation has incorrect parameter names
Daniel Baston
dbaston at gmail.com
Wed Apr 27 05:06:48 PDT 2016
Author: dbaston
Date: 2016-04-27 05:06:48 -0700 (Wed, 27 Apr 2016)
New Revision: 14862
branches/2.2/doc/reference_raster.xml
Modified: branches/2.2/doc/reference_raster.xml
--- branches/2.2/doc/reference_raster.xml 2016-04-27 12:03:24 UTC (rev 14861)
+++ branches/2.2/doc/reference_raster.xml 2016-04-27 12:06:48 UTC (rev 14862)
@@ -4417,23 +4417,23 @@
<funcprototype>
<funcdef>double precision <function>ST_Value</function></funcdef>
<paramdef><type>raster </type> <parameter>rast</parameter></paramdef>
- <paramdef><type>integer </type> <parameter>bandnum</parameter></paramdef>
+ <paramdef><type>integer </type> <parameter>band</parameter></paramdef>
<paramdef><type>geometry </type> <parameter>pt</parameter></paramdef>
<paramdef choice="opt"><type>boolean </type> <parameter>exclude_nodata_value=true</parameter></paramdef>
</funcprototype>
<funcprototype>
- <paramdef><type>integer </type> <parameter>columnx</parameter></paramdef>
- <paramdef><type>integer </type> <parameter>rowy</parameter></paramdef>
+ <paramdef><type>integer </type> <parameter>x</parameter></paramdef>
+ <paramdef><type>integer </type> <parameter>y</parameter></paramdef>
</funcprototype>
<funcprototype>
</funcprototype>
</funcsynopsis>
