[postgis-tickets] r14861 - #3217, ST_Value documentation has incorrect parameter names
Daniel Baston
dbaston at gmail.com
Wed Apr 27 05:03:24 PDT 2016
Author: dbaston
Date: 2016-04-27 05:03:24 -0700 (Wed, 27 Apr 2016)
New Revision: 14861
trunk/doc/reference_raster.xml
Modified: trunk/doc/reference_raster.xml
--- trunk/doc/reference_raster.xml 2016-04-27 00:06:35 UTC (rev 14860)
+++ trunk/doc/reference_raster.xml 2016-04-27 12:03:24 UTC (rev 14861)
@@ -4417,23 +4417,23 @@
<funcprototype>
<funcdef>double precision <function>ST_Value</function></funcdef>
<paramdef><type>raster </type> <parameter>rast</parameter></paramdef>
- <paramdef><type>integer </type> <parameter>bandnum</parameter></paramdef>
+ <paramdef><type>integer </type> <parameter>band</parameter></paramdef>
<paramdef><type>geometry </type> <parameter>pt</parameter></paramdef>
<paramdef choice="opt"><type>boolean </type> <parameter>exclude_nodata_value=true</parameter></paramdef>
</funcprototype>
<funcprototype>
- <paramdef><type>integer </type> <parameter>columnx</parameter></paramdef>
- <paramdef><type>integer </type> <parameter>rowy</parameter></paramdef>
+ <paramdef><type>integer </type> <parameter>x</parameter></paramdef>
+ <paramdef><type>integer </type> <parameter>y</parameter></paramdef>
</funcprototype>
<funcprototype>
</funcprototype>
</funcsynopsis>
