[postgis-tickets] [PostGIS] #3645: Avoid loading logically deleted records from shapefiles
PostGIS trac at osgeo.org
Sat Dec 10 00:30:06 PST 2016
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:  shapefile
Comment (by strk):
 You might have deleted them on accident, for example
 There could be a:
   -L <policy> Logically-deleted records handling policy (skip*,keep,abort)
 Where "keep" would create a system boolean column "deleted" on the
 output table.
 This would be similar to the existing:
   -N <policy> NULL geometries handling policy (insert*,skip,abort).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3645#comment:11>
