[postgis-tickets] [PostGIS] #3423: CREATE EXTENSION postgis fails with "ERROR: could not load library "/usr/pgsql-9.5/lib/postgis-2.2.so": /usr/pgsql-9.5/lib/postgis-2.2.so: undefined symbol: GEOSClipByRect"
trac at osgeo.org
Mon Feb 1 06:58:30 PST 2016
Reporter: motiumansky | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.2
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Comment (by robe):
Did you run ldconfig? That error usually happens if you compiled with say
GEOS 3.5 but your postgis at runtime is pointing at GEOS 3.4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3423#comment:14>
