[postgis-tickets] [PostGIS] #3430: dump/restore of tiger geocoder extension fails
trac at osgeo.org
Mon Feb 1 07:37:17 PST 2016
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.9
Component: tiger geocoder | Version: 2.1.x
Resolution: | Keywords:
Comment (by robe):
Two issues going on here:
1) Is it possible this database started off with installing tiger geocoder
with scripts and then got converted to EXTENSION using the unpackaged
routine? It's been a while since I tested the
FROM unpackaged route so that might be out of date
2) the duplicate key thing with set_geocode_setting. I thought I had
fixed that in 2.1, but it's possible I didn't or only fixed in 2.2 series.
So I'll check on that.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3430#comment:7>
