[postgis-tickets] [PostGIS] #3446: [raster] Error with topology reported on clean geometries when using ST_Intersection
trac at osgeo.org
Thu Feb 4 05:10:25 PST 2016
ST_Intersection
Reporter: gdrolet | Owner: dustymugs
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.2.2
Component: raster | Version: trunk
Keywords: raster ST_Intersectino |
I get the following error when using ST_Intersection (raster, geometry) in
development version 2.3:
ERROR: GEOSIntersects: TopologyException: side location conflict at
1749960.0258611713 1220621.9908729347
CONTEXT: PL/pgSQL function _st_intersects(geometry,raster,integer) line
22 at RETURN
PL/pgSQL function st_intersection(geometry,raster,integer) line 5 at
assignment
SQL function "st_intersection" statement 1
The call that generates this error is:
SELECT ST_Intersection(rt.rast, gt.geom) gv
FROM raster_100x100_indb_single rt,
polygons gt
WHERE ST_Intersects(rt.rast, gt.geom) and
gid = 7
Version with the error is:
postgis_full_version | POSTGIS="2.3.0dev r14604" GEOS="3.5.0-CAPI-1.9.0
r4090" PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.0.1, released
2015/09/15" LIBXML="2.7.8" LIBJSON="0.12" RASTER
No error is thrown when using the exact same query on the exact same data
with this version:
postgis_full_version | POSTGIS="2.1.8 r13780" GEOS="3.4.2-CAPI-1.8.2
r3924" PROJ
="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.11.1, released 2014/09/24"
LIBXML="2.7.
8" LIBJSON="UNKNOWN" TOPOLOGY RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3446>
