[postgis-tickets] [PostGIS] #3448: ST_Distance yields inconsistent results when used in a statement involving multiple Point and Multipolygon Geography pairs
PostGIS trac at osgeo.org
Fri Feb 5 12:32:24 PST 2016
 Reporter:  ewcz                           |      Owner:  pramsey
     Type:  defect                         |     Status:  new
 Priority:  medium                         |  Milestone:  PostGIS 2.2.2
Component:  postgis                        |    Version:  2.2.x
 Keywords:  ST_Distance, _ST_DistanceTree  |
 The function `ST_Distance` returns inconsistent results when calculating
 the mutual geographical distance of several points with respect to given
 (multi)polygon.
 Using the tables as in the attached minimal example, following SQL
 statement works as expected:
 sample=# SELECT N.node_id, P.iid, ST_Distance(P.outline::geography,
 N.location::geography)
 FROM N, P WHERE (N.node_id IN (2) AND P.iid=1);
  node_id | iid |   st_distance
        2 |   1 | 1730626.41376862
 (1 row)
 While a similar statement taking into account all three points gives wrong
 distance for the second point, i.e.,
 FROM N, P WHERE (N.node_id IN (1,2,3) AND P.iid=1);
        1 |   1 | 1951140.06556506
        2 |   1 |                0
        3 |   1 | 1727662.98350914
 (3 rows)
 However, using `_ST_DistanceUnCached` in the latter statement recovers the
 expected result:
 _ST_DistanceUnCached(P.outline::geography, N.location::geography)
  node_id | iid | _st_distanceuncached
 (3 rows)
 Statements above were tested on:
 PostgreSQL 9.5.0 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5
 20150623
 (Red Hat 4.8.5-4), 64-bit
 POSTGIS="2.2.1 r14555" GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.8.0, 6
 March 2012"
 GDAL="GDAL 1.11.2, released 2015/02/10" LIBXML="2.9.1"
 LIBJSON="0.11" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3448>
