[postgis-tickets] [PostGIS] #3441: [raster] Create out-db file using ST_AddBand
PostGIS trac at osgeo.org
Fri Feb 5 14:42:36 PST 2016
  Reporter:  gdrolet      |      Owner:  robe
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 2.3.0
 Component:  raster       |    Version:  trunk
Resolution:  wontfix      |   Keywords:  ST_AddBand, out-db
Comment (by gdrolet):
 Replying to [comment:6 dustymugs]:
 > @robe. I think gdrolet is asking that ST_AddBand create the out-db file
 if one is found at the path indicated. This will never happen as out-db is
 intentionally read-only to mitigate any security risks.
 I was asking that ST_AddBand create the out-db file if one is '''NOT'''
 found at the path indicated (and the user has write permission at the path
 location). Would that be possible?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3441#comment:9>
