[postgis-tickets] [PostGIS] #3451: Schema-qualify table names to avoid search path confusion or "column does not exist" error
trac at osgeo.org
Mon Feb 8 11:14:29 PST 2016
not exist" error
Reporter: mst | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.2
Component: tiger | Version: 2.2.x
geocoder | Keywords: table name, column does not exist,
Resolution: | schema
Comment (by mst):
Some addresses may not get located, returning the error. Original
assumption that this was only a problem with unlocatable addresses
appeared not to be the case. Renaming the other county table in the
database allowed more locations and null values to be correctly returned.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3451#comment:1>
