[postgis-tickets] [PostGIS] #3453: PostGIS JDBC Driver extension inconsistencies
PostGIS trac at osgeo.org
Mon Feb 8 22:29:50 PST 2016
 Reporter:  manaeem  |      Owner:  bergun
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS Java
Component:  java     |    Version:  2.1.x
 Keywords:           |
 While using postgis-2.1.8.tar.gz PostGIS JDBC extension with PG9.5
 following anomalies are observed i.e.
 1. Version.getFullVersion() method returning wrong version i.e.
 PostGIS JDBC V2.0.0
     It seems that related version information require to be updated i.e.
     java/jdbc/src/org/postgis/version.properties
       REL_MAJOR_VERSION=2
       REL_MINOR_VERSION=0
       REL_MICRO_VERSION=0
 2. Test case java/jdbc/src/examples/TestParser.java fail with two type of
 errors i.e.
     A). There are # of failure because of "can not mix dimensionality in a
 geometry", It seems a test case bug.
 2016-02-05 11:19:54 PKT ERROR:  can not mix dimensionality in a geometry
 2016-02-05 11:19:54 PKT HINT:  "...IONM(POINT(10 10 20),POINT(20 20 20))"
 <-- parse error at position 52 within geometry
 2016-02-05 11:19:54 PKT STATEMENT:  SELECT
 geometry_in('GEOMETRYCOLLECTIONM(POINT(10 10 20),POINT(20 20 20))')
         Test case output snippet i.e.
 Testing on connection 0: postgres
 --- Server side error: org.postgresql.util.PSQLException: ERROR: can not
   Hint: "...ONM(POINT(10 10 20),POINT(20 20 20))" <-- parse error at
 position 53 within geometry
 SQLout  :  GEOMETRYCOLLECTIONM(POINTM(10 10 20),POINTM(20 20 20))
 Eq SQLout: yes
 Prepared:  GEOMETRYCOLLECTIONM(POINTM(10 10 20),POINTM(20 20 20))
 Eq Prep: yes
 hexNWKT:   GEOMETRYCOLLECTIONM(POINTM(10 10 20),POINTM(20 20 20))
 equal    : yes
 hexXWKT:   GEOMETRYCOLLECTIONM(POINTM(10 10 20),POINTM(20 20 20))
 equal    : yes
 equal    : yes
 equal    : yes
         You can observe that test case is using POINT instead of POINTM
 for some cases that is troubling PostGIS.
     B). Second set of errors are failing with following errors i.e.
 2016-02-05 11:19:55 PKT ERROR:  parse error - invalid geometry
 2016-02-05 11:19:55 PKT HINT:  "GEOMETRYCOLLECTION(EMPTY" <-- parse error
 at position 24 within geometry
 2016-02-05 11:19:55 PKT STATEMENT:  SELECT
 geometry_in('GEOMETRYCOLLECTION(EMPTY)')
         It looks like a bug to me that result in query like "SELECT
 geometry_in('GEOMETRYCOLLECTION(EMPTY)')" instead of "SELECT
 geometry_in('GEOMETRYCOLLECTION EMPTY')" i.e. new representation.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3453>
