[postgis-tickets] [PostGIS] #3450: 2.2 -> 2.3.0dev leaves 15 function behind
PostGIS trac at osgeo.org
Tue Feb 9 00:35:58 PST 2016
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 2.3.0
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:                         |   Keywords:
Comment (by strk):
 r14632 also removes special handling of CAST and threats the same postgis
 and raster upgrades.
 I've tested this with:
 cd regress
 run_test.pl --extension --upgrade --upgrade-path 2.2.1--2.3.0dev
 tickets.sql
 Which reports no problem.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3450#comment:14>
