[postgis-tickets] r14633 - Unregister all functions before starting postgis extention upgrade
Sandro Santilli strk at keybit.net
Tue Feb 9 01:00:53 PST 2016
Author: strk
Date: 2016-02-09 01:00:53 -0800 (Tue, 09 Feb 2016)
New Revision: 14633
Removed:
   tags/2.2.0/extensions/postgis/sql_bits/remove_from_extension.sql.in
   tags/2.2.0/extensions/postgis/Makefile.in
   tags/2.2.0/postgis/postgis_drop_after.sql
Also drop temporarely introduced ST_AsTWKB signature.
See #3450
Modified: tags/2.2.0/extensions/postgis/Makefile.in
--- tags/2.2.0/extensions/postgis/Makefile.in	2016-02-09 08:35:02 UTC (rev 14632)
+++ tags/2.2.0/extensions/postgis/Makefile.in	2016-02-09 09:00:53 UTC (rev 14633)
@@ -103,9 +103,12 @@
 #postgis_raster_upgrade_minor.sql is the one that contains both postgis AND raster
 #TODO: come up with a better name
-#TODO: what about postgis_drop_after.sql ? where does it fit ??
 sql_bits/postgis_raster_upgrade_minor.sql: ../postgis_extension_helper.sql sql_bits/postgis_upgrade.sql sql_bits/rtpostgis_upgrade.sql ../../doc/raster_comments.sql ../../doc/postgis_comments.sql ../postgis_extension_helper_uninstall.sql
 	echo '\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \quit' > $@
+	# NOTE: good functions are always re-added by the upgrade scripts,
+	#       so unregistering them all here ensures the removed ones
+	#       can be removed on upgrade.
+	echo "SELECT postgis_extension_remove_objects('postgis', 'FUNCTION');" >> $@
 	cat $^ >> $@
 sql_minor_upgrade: sql_bits/postgis_raster_upgrade_minor.sql
Deleted: tags/2.2.0/extensions/postgis/sql_bits/remove_from_extension.sql.in
--- tags/2.2.0/extensions/postgis/sql_bits/remove_from_extension.sql.in	2016-02-09 08:35:02 UTC (rev 14632)
+++ tags/2.2.0/extensions/postgis/sql_bits/remove_from_extension.sql.in	2016-02-09 09:00:53 UTC (rev 14633)
@@ -1,29 +0,0 @@
--- PostGIS - Spatial Types for PostgreSQL
--- http://postgis.net
--- Copyright (C) 2011 Regina Obe <lr at pcorp.us>
--- This is free software; you can redistribute and/or modify it under
--- the terms of the GNU General Public Licence. See the COPYING file.
--- Author: Regina Obe <lr at pcorp.us>
--- This drops extension helper functions
--- and should be called at the end of the extension upgrade file
--- removes all postgis_topology functions from postgis_topology extension since they will be readded
--- during upgrade
-SELECT postgis_extension_remove_objects('postgis', 'FUNCTION');
-SELECT postgis_extension_remove_objects('postgis', 'AGGREGATE');
-SELECT postgis_extension_drop_if_exists('postgis', 'DROP VIEW raster_columns');
-SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE wktgeomval');
-SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE _wktgeomval');
-SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE raster_columns');
-SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE _raster_columns');
--- these got changed to out paramters in 2.1
-SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE summarystats');
-SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE quantile');
-SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE valuecount');
-SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE histogram');
Modified: tags/2.2.0/postgis/postgis_drop_after.sql
--- tags/2.2.0/postgis/postgis_drop_after.sql	2016-02-09 08:35:02 UTC (rev 14632)
+++ tags/2.2.0/postgis/postgis_drop_after.sql	2016-02-09 09:00:53 UTC (rev 14633)
@@ -147,3 +147,4 @@
 DROP FUNCTION IF EXISTS ST_AsBinary(text); -- deprecated in 2.0
 DROP FUNCTION IF EXISTS postgis_uses_stats(); -- deprecated in 2.0
+DROP FUNCTION IF EXISTS st_astwkb(geometry,integer,bigint,bool,bool); -- temporarely introduced before 2.2.0 final
