[postgis-tickets] r14636 - Fix mistakenly committed block (see #3450)
Sandro Santilli
strk at keybit.net
Tue Feb 9 01:06:39 PST 2016
Author: strk
Date: 2016-02-09 01:06:38 -0800 (Tue, 09 Feb 2016)
New Revision: 14636
tags/2.2.0/extensions/postgis/Makefile.in
Modified: tags/2.2.0/extensions/postgis/Makefile.in
--- tags/2.2.0/extensions/postgis/Makefile.in 2016-02-09 09:01:07 UTC (rev 14635)
+++ tags/2.2.0/extensions/postgis/Makefile.in 2016-02-09 09:06:38 UTC (rev 14636)
@@ -95,10 +95,6 @@
#TODO: come up with a better name
sql_bits/postgis_raster_upgrade_minor.sql: ../postgis_extension_helper.sql sql_bits/postgis_upgrade.sql sql_bits/rtpostgis_upgrade.sql ../../doc/raster_comments.sql ../../doc/postgis_comments.sql ../postgis_extension_helper_uninstall.sql
echo '\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \quit' > $@
- # NOTE: good functions are always re-added by the upgrade scripts,
- # so unregistering them all here ensures the removed ones
- # can be removed on upgrade.
- echo "SELECT postgis_extension_remove_objects('postgis', 'FUNCTION');" >> $@
cat $^ >> $@
sql_minor_upgrade: sql_bits/postgis_raster_upgrade_minor.sql
