[postgis-tickets] [PostGIS] #3450: 2.2 -> 2.3.0dev leaves 15 function behind
trac at osgeo.org
Tue Feb 9 01:27:02 PST 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: build/upgrade/install | Version: 2.2.x
Resolution: | Keywords:
Changes (by strk):
* cc: David, Fetter, <david@…> (added)
Comment:
The problem is not with the postgis_extension_drop_if_exists function but
with ALTER EXTENSION itself !
strk=# alter extension postgis DROP FUNCTION
pgis_twkb_accum_finalfn(internal);
ALTER EXTENSION
strk=# DROP FUNCTION pgis_twkb_accum_finalfn(internal);
ERROR: cannot drop function pgis_twkb_accum_finalfn(internal) because
other objects depend on it
DETAIL: extension postgis depends on function
strk=# select version();
version
PostgreSQL 9.3.6 on x86_64-unknown-linux-gnu, compiled by gcc (Ubuntu
4.8.2-19ubuntu1) 4.8.2, 64-bit
(1 row)
David maybe this is one of those things that would help if done upstream
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3450#comment:22>
