[postgis-tickets] [PostGIS] #3450: 2.2 -> 2.3.0dev leaves 15 function behind
PostGIS trac at osgeo.org
Tue Feb 9 01:42:21 PST 2016
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 2.3.0
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:                         |   Keywords:
Comment (by strk):
 Figured: the function is actually a dependency of an aggregate, which is
 NOT removed at the time of DROP FUNCTION. So the only issue with
 PostgreSQL is that the error message is confusing, not giving the direct
 dependent of the function
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3450#comment:24>
