[postgis-tickets] r14638 - Drop temporarely added tkwb aggregate and support functions
Sandro Santilli strk at keybit.net
Tue Feb 9 01:43:34 PST 2016
Author: strk
Date: 2016-02-09 01:43:33 -0800 (Tue, 09 Feb 2016)
New Revision: 14638
   trunk/postgis/postgis_drop_after.sql
These were added during 2.2.0 development
but removed before going final.
See #3450
Modified: trunk/postgis/postgis_drop_after.sql
--- trunk/postgis/postgis_drop_after.sql	2016-02-09 09:09:01 UTC (rev 14637)
+++ trunk/postgis/postgis_drop_after.sql	2016-02-09 09:43:33 UTC (rev 14638)
@@ -28,6 +28,14 @@
 DROP AGGREGATE IF EXISTS accum_old(geometry);
 DROP AGGREGATE IF EXISTS st_accum_old(geometry);
+DROP AGGREGATE IF EXISTS st_astwkb_agg(geometry, integer); -- temporarely introduced before 2.2.0 final
+DROP AGGREGATE IF EXISTS st_astwkb_agg(geometry, integer, bigint); -- temporarely introduced before 2.2.0 final
+DROP AGGREGATE IF EXISTS st_astwkbagg(geometry, integer); -- temporarely introduced before 2.2.0 final
+DROP AGGREGATE IF EXISTS st_astwkbagg(geometry, integer, bigint); -- temporarely introduced before 2.2.0 final
+DROP AGGREGATE IF EXISTS st_astwkbagg(geometry, integer, bigint, boolean); -- temporarely introduced before 2.2.0 final
+DROP AGGREGATE IF EXISTS st_astwkbagg(geometry, integer, bigint, boolean, boolean); -- temporarely introduced before 2.2.0 final
 -- BEGIN Management functions that now have default param for typmod --
 DROP FUNCTION IF EXISTS AddGeometryColumn(varchar,varchar,varchar,varchar,integer,varchar,integer);
 DROP FUNCTION IF EXISTS AddGeometryColumn(varchar,varchar,varchar,integer,varchar,integer);
@@ -148,3 +156,8 @@
 DROP FUNCTION IF EXISTS postgis_uses_stats(); -- deprecated in 2.0
 DROP FUNCTION IF EXISTS st_astwkb(geometry,integer,bigint,bool,bool); -- temporarely introduced before 2.2.0 final
+DROP FUNCTION IF EXISTS pgis_twkb_accum_transfn(internal,geometry,integer); -- temporarely introduced before 2.2.0 final
+DROP FUNCTION IF EXISTS pgis_twkb_accum_transfn(internal,geometry,integer,bigint); -- temporarely introduced before 2.2.0 final
+DROP FUNCTION IF EXISTS pgis_twkb_accum_transfn(internal,geometry,integer,bigint,bool); -- temporarely introduced before 2.2.0 final
+DROP FUNCTION IF EXISTS pgis_twkb_accum_transfn(internal,geometry,integer,bigint,bool,bool); -- temporarely introduced before 2.2.0 final
+DROP FUNCTION IF EXISTS pgis_twkb_accum_finalfn(internal); -- temporarely introduced before 2.2.0 final
