[postgis-tickets] r14643 - Drop temporarely added tkwb aggregate and functions
Sandro Santilli strk at keybit.net
Tue Feb 9 02:14:50 PST 2016
Author: strk
Date: 2016-02-09 02:14:50 -0800 (Tue, 09 Feb 2016)
New Revision: 14643
   branches/2.2/postgis/postgis_drop_after.sql
These were added during 2.2.0 development
but removed before going final.
See #3450
Modified: branches/2.2/postgis/postgis_drop_after.sql
--- branches/2.2/postgis/postgis_drop_after.sql	2016-02-09 10:12:04 UTC (rev 14642)
+++ branches/2.2/postgis/postgis_drop_after.sql	2016-02-09 10:14:50 UTC (rev 14643)
@@ -28,6 +28,14 @@
 DROP AGGREGATE IF EXISTS accum_old(geometry);
 DROP AGGREGATE IF EXISTS st_accum_old(geometry);
+DROP AGGREGATE IF EXISTS st_astwkb_agg(geometry, integer); -- temporarely introduced before 2.2.0 final
+DROP AGGREGATE IF EXISTS st_astwkb_agg(geometry, integer, bigint); -- temporarely introduced before 2.2.0 final
+DROP AGGREGATE IF EXISTS st_astwkbagg(geometry, integer); -- temporarely introduced before 2.2.0 final
+DROP AGGREGATE IF EXISTS st_astwkbagg(geometry, integer, bigint); -- temporarely introduced before 2.2.0 final
+DROP AGGREGATE IF EXISTS st_astwkbagg(geometry, integer, bigint, boolean); -- temporarely introduced before 2.2.0 final
+DROP AGGREGATE IF EXISTS st_astwkbagg(geometry, integer, bigint, boolean, boolean); -- temporarely introduced before 2.2.0 final
 -- BEGIN Management functions that now have default param for typmod --
 DROP FUNCTION IF EXISTS AddGeometryColumn(varchar,varchar,varchar,varchar,integer,varchar,integer);
 DROP FUNCTION IF EXISTS AddGeometryColumn(varchar,varchar,varchar,integer,varchar,integer);
@@ -147,3 +155,9 @@
 DROP FUNCTION IF EXISTS ST_AsBinary(text); -- deprecated in 2.0
 DROP FUNCTION IF EXISTS postgis_uses_stats(); -- deprecated in 2.0
+DROP FUNCTION IF EXISTS st_astwkb(geometry,integer,bigint,bool,bool); -- temporarely introduced before 2.2.0 final
+DROP FUNCTION IF EXISTS pgis_twkb_accum_transfn(internal,geometry,integer); -- temporarely introduced before 2.2.0 final
+DROP FUNCTION IF EXISTS pgis_twkb_accum_transfn(internal,geometry,integer,bigint); -- temporarely introduced before 2.2.0 final
+DROP FUNCTION IF EXISTS pgis_twkb_accum_transfn(internal,geometry,integer,bigint,bool); -- temporarely introduced before 2.2.0 final
+DROP FUNCTION IF EXISTS pgis_twkb_accum_transfn(internal,geometry,integer,bigint,bool,bool); -- temporarely introduced before 2.2.0 final
+DROP FUNCTION IF EXISTS pgis_twkb_accum_finalfn(internal); -- temporarely introduced before 2.2.0 final
