[postgis-tickets] [PostGIS] #3450: 2.2 -> 2.3.0dev leaves 15 function behind
PostGIS trac at osgeo.org
Tue Feb 9 02:29:15 PST 2016
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 2.3.0
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:                         |   Keywords:
Comment (by strk):
 Left-over functions:
 strk=# select proname,pg_get_function_arguments(oid) from pg_proc where
 probin = '$libdir/postgis-2.2';
                proname               |      pg_get_function_arguments
  geometry_spgist_leaf_consistent_2d  | internal, geometry, integer
  geometry_spgist_inner_consistent_2d | internal, geometry, integer
  geometry_spgist_picksplit_2d        | internal, internal
  geometry_spgist_config_2d           | internal, internal
  geometry_spgist_choose_2d           | internal, internal
  st_seteffectivearea                 | geometry, double precision DEFAULT
 0
  geometry_distance_centroid          | geom1 gidx, geom2 gidx
  geometry_distance_box               | gidx1 gidx, gidx2 gidx
  geometry_distance_box_nd            | geom1 geometry, geom2 geometry
 (9 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3450#comment:32>
