[postgis-tickets] r14647 - Drop temporarely added geometry_distance_box_nd(geometry, geometry)
Sandro Santilli
strk at keybit.net
Tue Feb 9 02:55:45 PST 2016
Author: strk
Date: 2016-02-09 02:55:45 -0800 (Tue, 09 Feb 2016)
New Revision: 14647
branches/2.2/postgis/postgis_drop_after.sql
Drop temporarely added geometry_distance_box_nd(geometry,geometry)
Closes #3450
Modified: branches/2.2/postgis/postgis_drop_after.sql
--- branches/2.2/postgis/postgis_drop_after.sql 2016-02-09 10:51:00 UTC (rev 14646)
+++ branches/2.2/postgis/postgis_drop_after.sql 2016-02-09 10:55:45 UTC (rev 14647)
@@ -162,4 +162,6 @@
DROP FUNCTION IF EXISTS pgis_twkb_accum_transfn(internal,geometry,integer,bigint,bool,bool); -- temporarely introduced before 2.2.0 final
DROP FUNCTION IF EXISTS pgis_twkb_accum_finalfn(internal); -- temporarely introduced before 2.2.0 final
-DROP FUNCTION IF EXISTS st_seteffectivearea(geometry, double precision); -- temporarely introduced before 2.2.0 final
+DROP FUNCTION IF EXISTS st_seteffectivearea(geometry, double precision); -- temporarely introduced before 2.2.0 final
+DROP FUNCTION IF EXISTS geometry_distance_box_nd(geometry,geometry); -- temporarely introduced before 2.2.0 final
