[postgis-tickets] [PostGIS] #2688: make check RUNTESTFLAGS=--extension can't run on debbie
PostGIS trac at osgeo.org
Tue Feb 9 06:27:38 PST 2016
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  2.1.x
Resolution:             |   Keywords:
Comment (by robe):
 Well the thing is that the postgresql directories are under jenkins so
 they are already writeable.  The issue last I recall was that stuff tries
 to be installed in system.
 /usr/local/lib
 We might have fixed that issue though, cause as I recall on winnie, I
 think I'm using dest or something to prevent it from writing into
 /usr/local/lib.  So perhaps that is the solution.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2688#comment:8>
