[postgis-tickets] r14652 - Add --dumprestore switch to ./run_test.pl
Sandro Santilli strk at keybit.net
Tue Feb 9 08:18:51 PST 2016
Author: strk
Date: 2016-02-09 08:18:51 -0800 (Tue, 09 Feb 2016)
New Revision: 14652
   branches/2.2/regress/run_test.pl
See #3444
Modified: branches/2.2/regress/run_test.pl
--- branches/2.2/regress/run_test.pl	2016-02-09 15:47:59 UTC (rev 14651)
+++ branches/2.2/regress/run_test.pl	2016-02-09 16:18:51 UTC (rev 14652)
@@ -52,6 +52,7 @@
 my $OPT_NODROP = 0;
 my $OPT_NOCREATE = 0;
 my $OPT_UPGRADE = 0;
+my $OPT_DUMPRESTORE = 0;
 my $OPT_WITH_TOPO = 0;
 my $OPT_WITH_RASTER = 0;
 my $OPT_WITH_SFCGAL = 0;
@@ -69,6 +70,7 @@
 	'nodrop' => \$OPT_NODROP,
 	'upgrade' => \$OPT_UPGRADE,
 	'upgrade-path=s' => \$OPT_UPGRADE_PATH,
+	'dumprestore' => \$OPT_DUMPRESTORE,
 	'nocreate' => \$OPT_NOCREATE,
 	'topology' => \$OPT_WITH_TOPO,
 	'raster' => \$OPT_WITH_RASTER,
@@ -332,7 +334,12 @@
   $libver = sql("select postgis_lib_version()");
+if ( $OPT_DUMPRESTORE )
+  dump_restore();
 # Report PostGIS environment
@@ -490,6 +497,8 @@
   -v, --verbose   be verbose about failures
   --nocreate      do not create the regression database on start
   --upgrade       source the upgrade scripts on start
+  --upgrade-path  upgrade path, format <from>--<to>
+  --dumprestore   dump and restore spatially-enabled db before running tests
   --nodrop        do not drop the regression database on exit
   --raster        load also raster extension
   --topology      load also topology extension
@@ -497,7 +506,6 @@
   --clean         cleanup test logs on exit
   --expect        save obtained output as expected
   --extension     load using extensions
-  --upgrade-path  upgrade path, format <from>--<to>
@@ -1501,6 +1509,43 @@
 	return 0;
+# Dump and restore the database
+sub dump_restore
+  my $DBDUMP = $TMPDIR . '/' . $DB . ".dump";
+  my $rv;
+	print "Dumping and restoring database '${DB}'\n";
+  $rv = system("pg_dump -Fc ${DB} -f ${DBDUMP} >> $REGRESS_LOG 2>&1");
+  if ( $rv ) {
+    fail("Could not dump ${DB}", $REGRESS_LOG);
+		die;
+  $rv = system("dropdb ${DB} >> $REGRESS_LOG 2>&1");
+  if ( $rv ) {
+    fail("Could not drop ${DB}", $REGRESS_LOG);
+		die;
+  $rv = system("createdb ${DB} >> $REGRESS_LOG 2>&1");
+  if ( $rv ) {
+    fail("Could not create ${DB}", $REGRESS_LOG);
+		die;
+  $rv = system("pg_restore -d ${DB} ${DBDUMP} >> $REGRESS_LOG 2>&1");
+  if ( $rv ) {
+    fail("Could not restore ${DB}", $REGRESS_LOG);
+    die;
+  unlink($DBDUMP);
+  return 1;
 sub diff
 	my ($expected_file, $obtained_file) = @_;
