[postgis-tickets] r14656 - Re-append "topology" schema on restore, with --dumprestore
Sandro Santilli strk at keybit.net
Tue Feb 9 10:20:56 PST 2016
Author: strk
Date: 2016-02-09 10:20:56 -0800 (Tue, 09 Feb 2016)
New Revision: 14656
   branches/2.2/regress/run_test.pl
See #3454
Modified: branches/2.2/regress/run_test.pl
--- branches/2.2/regress/run_test.pl	2016-02-09 18:20:36 UTC (rev 14655)
+++ branches/2.2/regress/run_test.pl	2016-02-09 18:20:56 UTC (rev 14656)
@@ -1539,8 +1539,21 @@
   if ( $rv ) {
     fail("Could not restore ${DB}", $REGRESS_LOG);
     die;
+  if ( $OPT_WITH_TOPO )
+    # We need to re-add "topology" to the search_path as it is lost
+    # on dump/reload, see https://trac.osgeo.org/postgis/ticket/3454
+    my $psql_opts = "--no-psqlrc --variable ON_ERROR_STOP=true";
+    my $cmd = "psql $psql_opts -c \"SELECT topology.AddToSearchPath('topology')\" $DB >> $REGRESS_LOG 2>&1";
+    $rv = system($cmd);
+    if ( $rv ) {
+      fail("Error encountered adding topology to search path after restore", $REGRESS_LOG);
+      die;
   unlink($DBDUMP);
   return 1;
