[postgis-tickets] [PostGIS] #3447: PG::InternalError: ERROR: Error computing Voronoi diagram.
trac at osgeo.org
Tue Feb 9 15:39:57 PST 2016
Reporter: loarie | Owner: dbaston
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: postgis | Version: trunk
Resolution: | Keywords: ST_Voronoi
Comment (by dbaston):
Thanks for the example loarie. Here are my observations so far:
- The problem occurs within GEOS.
- JTS has no problem producing a Voronoi diagram for this input.
- ST_DelaunayTriangles has no problem with this input; I'd have expected
both or none to work
I'll keep looking around to see if I can turn up anything obvious.
GEOS error is {{{IllegalArgumentException: Points of LinearRing do not
form a closed linestring}}}, from
#0 0x00007f93f2c498b0 in __cxa_throw () from /usr/lib/x86_64-linux-
gnu/libstdc++.so.6
#1 0x00007f93f2fae617 in geos::geom::LinearRing::validateConstruction
(this=this at entry=0x7f94068cbc00) at LinearRing.cpp:70
#2 0x00007f93f2fae71b in geos::geom::LinearRing::LinearRing
(this=0x7f94068cbc00, newCoords=0x7f94068cbbe0, newFactory=<optimized
out>, __in_chrg=<optimized out>, __vtt_parm=<optimized out>)
at LinearRing.cpp:46
#3 0x00007f93f2fac115 in geos::geom::GeometryFactory::createLinearRing
(this=this at entry=0x7f94067fa4a0, newCoords=newCoords at entry=0x7f94068cbbe0)
at GeometryFactory.cpp:469
#4 0x00007f93f303531b in
geos::triangulate::quadedge::QuadEdgeSubdivision::getVoronoiCellPolygon
(this=this at entry=0x7f940689efa0, qe=<optimized out>, geomFact=...) at
QuadEdgeSubdivision.cpp:582
#5 0x00007f93f3036c0e in
geos::triangulate::quadedge::QuadEdgeSubdivision::getVoronoiCellPolygons
(this=0x7f940689efa0, geomFact=...) at QuadEdgeSubdivision.cpp:528
#6 0x00007f93f3036cc9 in
geos::triangulate::quadedge::QuadEdgeSubdivision::getVoronoiDiagram
(this=<optimized out>, geomFact=...) at QuadEdgeSubdivision.cpp:505
#7 0x00007f93f303265b in
geos::triangulate::VoronoiDiagramBuilder::getDiagram
(this=this at entry=0x7ffd18db06d0, geomFact=...) at
VoronoiDiagramBuilder.cpp:106
#8 0x00007f93f414042e in GEOSVoronoiDiagram_r (extHandle=0x7f94067fa050,
g1=0x7f94068bb7e0, env=0x0, tolerance=0, onlyEdges=0) at
geos_ts_c.cpp:6519
#9 0x00007f93f43c7fab in lwgeom_voronoi_diagram
(g=g at entry=0x7f940683a670, env=env at entry=0x0, tolerance=tolerance at entry=0,
output_edges=0) at lwgeom_geos.c:2013
#10 0x00007f93f4374977 in ST_Voronoi (fcinfo=0x7f94068159e0) at
lwgeom_geos.c:3611
#11 0x00007f94042882f3 in ?? ()
#12 0x00007f940428debc in ExecProject ()
#13 0x00007f9404293f90 in ExecAgg ()
#14 0x00007f9404287068 in ExecProcNode ()
#15 0x00007f94042845e2 in standard_ExecutorRun ()
#16 0x00007f9404367edf in ?? ()
#17 0x00007f94043694aa in PortalRun ()
#18 0x00007f9404366e65 in PostgresMain ()
#19 0x00007f940415a280 in ?? ()
#20 0x00007f9404321ab1 in PostmasterMain ()
#21 0x00007f940415af03 in main ()
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3447#comment:4>
