[postgis-tickets] [PostGIS] #3457: When a geometry is smaller than a raster but their extents are the same, one of the overloads of ST_Clip doesn't give expected output
PostGIS trac at osgeo.org
Thu Feb 11 18:31:03 PST 2016
 Reporter:  GMudambi  |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  critical  |  Milestone:  PostGIS 2.1.9
Component:  postgis   |    Version:  2.1.x
 Keywords:            |
 Consider a square geometry
 ST_GeomFromText('POLYGON((0 0,100 0,100 100,0 100,0 0))',4326)
 Let us create a raster out of it.
 ST_ASRaster(
 ST_GeomFromText('POLYGON((0 0,100 0,100 100,0 100,0 0))',4326),
 ST_Addband(ST_MakeEmptyRaster(1,1,0,0,1,-1,0,0,4326),'32BF'::text,0,-1),'32BF'::text,1,-1)
 ----- {1}
 Consider another geometry whose extent (Envelope) is same the raster but
 is actually smaller.
 For Ex:
 ST_GeomFromText('POLYGON((0 0,100 100,100 0,0 0))',4326) ----- {2}
 Clipping {1} and {2} and dumping the raster as polygons should give us a
 polygon closer to a  triangle but gives us a square output.
 This behaves right in 2.1.3 version but has got changed from 2.1.4
 Query:
 SELECT
 ST_AsText((ST_DumpAsPolygons(ST_Clip(ST_ASRaster(ST_GeomFromText('POLYGON((0
 0))',4326),ST_Addband(ST_MakeEmptyRaster(1,1,0,0,1,-1,0,0,4326),'32BF'::text,0,-1),'32BF'::text,1,-1),
 ST_GeomFromText('POLYGON((0 0,100 100,100 0,0 0))',4326)))).geom)
 PostGis v2.1.3
 POLYGON((99 99,99 98,98 98,98 97,97 97,97 96,96 96,96 95,95 95,95 94,94
 94,94 93,93 93,93 92,92 92,92 91,91 91,91 90,90 90,90 89,89 89,89 88,88
 88,88 87,87 87,87 86,86 86,86 85,85 85,85 84,84 84,84 83,83 83,83 82,82
 82,82 81,81 81,81 80,80 80,80 79,79 79,79 78,78 78,78 77,77 77,77 76,76
 76,76 75,75 75,75 74,74 74,74 73,73 73,73 72,72 72,72 71,71 71,71 70,70
 70,70 69,69 69,69 68,68 68,68 67,67 67,67 66,66 66,66 65,65 65,65 64,64
 64,64 63,63 63,63 62,62 62,62 61,61 61,61 60,60 60,60 59,59 59,59 58,58
 58,58 57,57 57,57 56,56 56,56 55,55 55,55 54,54 54,54 53,53 53,53 52,52
 52,52 51,51 51,51 50,50 50,50 49,49 49,49 48,48 48,48 47,47 47,47 46,46
 46,46 45,45 45,45 44,44 44,44 43,43 43,43 42,42 42,42 41,41 41,41 40,40
 40,40 39,39 39,39 38,38 38,38 37,37 37,37 36,36 36,36 35,35 35,35 34,34
 34,34 33,33 33,33 32,32 32,32 31,31 31,31 30,30 30,30 29,29 29,29 28,28
 28,28 27,27 27,27 26,26 26,26 25,25 25,25 24,24 24,24 23,23 23,23 22,22
 22,22 21,21 21,21 20,20 20,20 19,19 19,19 18,18 18,18 17,17 17,17 16,16
 16,16 15,15 15,15 14,14 14,14 13,13 13,13 12,12 12,12 11,11 11,11 10,10
 10,10 9,9 9,9 8,8 8,8 7,7 7,7 6,6 6,6 5,5 5,5 4,4 4,4 3,3 3,3 2,2 2,2 1,1
 1,1 0,99 0,100 0,100 99,99 99))
 PostGis v2.1.4+
 POLYGON((0 100,0 0,100 0,100 100,0 100))
 The issue seems to stem from the fact that in ST_Clip function, we have a
 short-circuit SQL.
 -- short-cut if geometry's extent fully contains raster's extent
 IF (nodataval IS NULL OR array_length(nodataval, 1) < 1) AND geom ~
 ST_Envelope(rast) THEN
        RETURN rast;
 END IF;
 geom ~ ST_Envelope(rast) is a necessary but not a sufficient condition for
 the short cut.
 One of the sufficiency condition here could be
 ST_Contains(geom, ST_Envelope(rast))
 which ensures that the rast is completely enveloped by the geometry (not
 just its bounding box).
 The change occurred as part of this enhancement ticket
 https://trac.osgeo.org/postgis/ticket/2829
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3457>
