[postgis-tickets] [PostGIS] #3459: Website looks strange
PostGIS trac at osgeo.org
Mon Feb 15 07:56:35 PST 2016
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.2.2
Component:  website  |    Version:  2.2.x
 Keywords:           |
 Seems something is wrong with our website.  Perhaps cache went out of
 wack.  The css does not seem to render and when I manually run the update
 script I get:
 Can't copy
 '/var/www/postgis_website/_piecrust_1.2.0/libs/geshi/geshi/geshi/thinbasic.php'
 to
 '/var/www/postgis_website/_counter/_piecrust_1.2.0/libs/geshi/geshi/geshi/thinbasic.php'.
 Looks like out of disk space:
 Filesystem      Size  Used Avail Use% Mounted on
 rootfs             -     -     -    - /
 sysfs              0     0     0    - /sys
 proc               0     0     0    - /proc
 udev             11M     0   11M   0% /dev
 devpts             0     0     0    - /dev/pts
 tmpfs           422M   43M  380M  11% /run
 /dev/sda1        85G   85G     0 100% /
 securityfs         0     0     0    - /sys/kernel/security
 tmpfs           1.1G  8.2k  1.1G   1% /dev/shm
 tmpfs           5.3M     0  5.3M   0% /run/lock
 tmpfs           1.1G     0  1.1G   0% /sys/fs/cgroup
 I suspect old jenkins stuff is eating a lot of space so I'll start
 clearing that out.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3459>
