[postgis-tickets] r14663 - add 2.2.1 release notes (forgot to do that after release of 2.2.1)
Regina Obe
lr at pcorp.us
Mon Feb 15 21:08:25 PST 2016
Author: robe
Date: 2016-02-15 21:08:24 -0800 (Mon, 15 Feb 2016)
New Revision: 14663
trunk/doc/release_notes.xml
Modified: trunk/doc/release_notes.xml
--- trunk/doc/release_notes.xml 2016-02-16 04:45:07 UTC (rev 14662)
+++ trunk/doc/release_notes.xml 2016-02-16 05:08:24 UTC (rev 14663)
@@ -3,9 +3,46 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
+ <sect1>
+ <title>Release 2.2.1</title>
+ <para>Release date: 2016/01/06</para>
+ <para>This is a bug fix and performance improvement release.</para>
+ <simplesect>
+ <title>New Features</title>
+ <para>#2232, avoid accumulated error in SVG rounding</para>
+ <para>#3321, Fix performance regression in topology loading</para>
+ <para>#3329, Fix robustness regression in TopoGeo_addPoint</para>
+ <para>#3349, Fix installation path of postgis_topology scripts</para>
+ <para>#3351, set endnodes isolation on ST_RemoveIsoEdge
+ (and lwt_RemIsoEdge)</para>
+ <para>#3355, geography ST_Segmentize has geometry bbox </para>
+ <para>#3359, Fix toTopoGeom loss of low-id primitives from
+ TopoGeometry definition</para>
+ <para>#3360, _raster_constraint_info_scale invalid input syntax</para>
+ <para>#3375, crash in repeated point removal for collection(point)</para>
+ <para>#3378, Fix handling of hierarchical TopoGeometries
+ in presence of multiple topologies</para>
+ <para>#3380, #3402, Decimate lines on topology load</para>
+ <para>#3388, #3410, Fix missing end-points in ST_Removepoints</para>
+ <para>#3389, Buffer overflow in lwgeom_to_geojson</para>
+ <para>#3390, Compilation under Alpine Linux 3.2
+ gives an error when compiling the postgis and postgis_topology extension</para>
+ <para>#3393, ST_Area NaN for some polygons</para>
+ <para>#3401, Improve ST_Split robustness on 32bit systems</para>
+ <para>#3404, ST_ClusterWithin crashes backend</para>
+ <para>#3407, Fix crash on splitting a face or an edge
+ defining multiple TopoGeometry objects</para>
+ <para>#3411, Clustering functions not using spatial index</para>
+ <para>#3412, Improve robustness of snapping step in TopoGeo_addLinestring</para>
+ <para>#3415, Fix OSX 10.9 build under pkgsrc</para>
+ <para>Fix memory leak in lwt_ChangeEdgeGeom [liblwgeom]</para>
+ </simplesect>
+ </sect1>
<sect1>
- <title>Release 2.2.0</title>
- <para>Release date: 2015/10/07</para>
+ <title>Release 2.2.0</title>
+ <para>Release date: 2015/10/07</para>
<para>This is a new feature release, with new functions, improved performance, and other goodies.</para>
<simplesect>
