[postgis-tickets] [PostGIS] #3460: Upgrade to 2.2 doesn't adjust size of pgis_abs type
PostGIS trac at osgeo.org
Sat Feb 20 08:28:29 PST 2016
 Reporter:  dbaston  |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  high     |  Milestone:  PostGIS 2.2.2
Component:  postgis  |    Version:  2.2.x
 Keywords:           |
 The size of the {{{pgis_abs}}} type was changed from 8 bytes to 16 bytes
 in 2.2.0.  It doesn't appear that the upgrade procedure handles this, so
 if you upgrade to 2.2.x from a previous version, Postgres would still
 think the size is 8 bytes.
 I haven't been able to show this, because I can't actually perform an
 upgrade from 2.1.x to more recent versions due to #3429.  But this seems
 like it would explain the following issue reported to postgis-users:
 On Wed, Feb 17, 2016 at 01:44:54PM +0100, Ronnie Lassche wrote:
 > I’m trying to use the new st_clusterwithin function, but it keeps
 failing.
 > I’ve tried to cluster 20 points with the following query.
 > SELECT ST_ClusterWithin(geom, 50) FROM winkels
 > Most of the times I get the message
 > “ERROR: Tolerance not defined
 > A few times it did work and gave me a result, but trying again will lead
 to
 > the same error.
 > I’m working with postgis 2.2.2dev (but also tried it with 2.2.0).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3460>
