[postgis-tickets] r14681 - Added parameters for geography buffering from @tbonfort
Paul Ramsey
pramsey at cleverelephant.ca
Wed Feb 24 07:59:10 PST 2016
Author: pramsey
Date: 2016-02-24 07:59:10 -0800 (Wed, 24 Feb 2016)
New Revision: 14681
trunk/doc/reference_processing.xml
trunk/postgis/geography.sql.in
https://github.com/postgis/postgis/pull/11
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml 2016-02-24 15:19:04 UTC (rev 14680)
+++ trunk/doc/reference_processing.xml 2016-02-24 15:59:10 UTC (rev 14681)
@@ -39,7 +39,21 @@
<paramdef><type>geography </type> <parameter>g1</parameter></paramdef>
<paramdef><type>float </type> <parameter>radius_of_buffer_in_meters</parameter></paramdef>
</funcprototype>
+ <funcprototype>
+ <funcdef>geography <function>ST_Buffer</function></funcdef>
+ <paramdef><type>geography </type> <parameter>g1</parameter></paramdef>
+ <paramdef><type>float </type> <parameter>radius_of_buffer</parameter></paramdef>
+ <paramdef><type>integer </type> <parameter>num_seg_quarter_circle</parameter></paramdef>
+ </funcprototype>
+ <funcprototype>
+ <paramdef><type>text </type> <parameter>buffer_style_parameters</parameter></paramdef>
+ </funcprototype>
</funcsynopsis>
</refsynopsisdiv>
Modified: trunk/postgis/geography.sql.in
--- trunk/postgis/geography.sql.in 2016-02-24 15:19:04 UTC (rev 14680)
+++ trunk/postgis/geography.sql.in 2016-02-24 15:59:10 UTC (rev 14681)
@@ -742,6 +742,18 @@
AS 'SELECT geography(ST_Transform(ST_Buffer(ST_Transform(geometry($1), _ST_BestSRID($1)), $2), 4326))'
LANGUAGE 'sql' IMMUTABLE STRICT;
+-- Availability: 2.1.x
+CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, integer)
+ RETURNS geography
+ AS 'SELECT geography(ST_Transform(ST_Buffer(ST_Transform(geometry($1), _ST_BestSRID($1)), $2, $3), 4326))'
+ LANGUAGE 'sql' IMMUTABLE STRICT;
+CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, cstring)
+ RETURNS geography
-- Availability: 1.5.0 - this is just a hack to prevent unknown from causing ambiguous name because of geography
CREATE OR REPLACE FUNCTION ST_Buffer(text, float8)
RETURNS geometry AS
