[postgis-tickets] r14686 - #3437, ST_Intersects incorrect for MultiPoints
Daniel Baston
dbaston at gmail.com
Wed Feb 24 08:35:19 PST 2016
Author: dbaston
Date: 2016-02-24 08:35:19 -0800 (Wed, 24 Feb 2016)
New Revision: 14686
trunk/postgis/lwgeom_geos_prepared.c
trunk/regress/tickets.sql
trunk/regress/tickets_expected
Modified: trunk/postgis/lwgeom_geos_prepared.c
--- trunk/postgis/lwgeom_geos_prepared.c 2016-02-24 16:25:57 UTC (rev 14685)
+++ trunk/postgis/lwgeom_geos_prepared.c 2016-02-24 16:35:19 UTC (rev 14686)
@@ -338,7 +338,17 @@
lwpgerror("PrepGeomCacheBuilder asked to build new prepcache where one already exists.");
return LW_FAILURE;
+ * Avoid creating a PreparedPoint around a Point or a MultiPoint.
+ * Consider changing this behavior in the future if supported GEOS
+ * versions correctly handle prepared points and multipoints and
+ * provide a performance benefit.
+ * See https://trac.osgeo.org/postgis/ticket/3437
+ if (lwgeom_get_type(lwgeom) == POINTTYPE || lwgeom_get_type(lwgeom) == MULTIPOINTTYPE)
+ return LW_FAILURE;
prepcache->geom = LWGEOM2GEOS( lwgeom , 0);
if ( ! prepcache->geom ) return LW_FAILURE;
Modified: trunk/regress/tickets.sql
--- trunk/regress/tickets.sql 2016-02-24 16:25:57 UTC (rev 14685)
+++ trunk/regress/tickets.sql 2016-02-24 16:35:19 UTC (rev 14686)
@@ -937,5 +937,20 @@
+-- #3437
+WITH
+mp AS (SELECT ST_Collect(ST_MakePoint(-c, c*c)) AS geom FROM generate_series(1, 5) c),
+p AS (SELECT (ST_Dump(geom)).geom FROM mp)
+SELECT '#3437a' AS t, count(*) FROM mp INNER JOIN p ON ST_Intersects(mp.geom, p.geom)
+UNION ALL
+SELECT '#3437b' AS t, count(*) FROM mp INNER JOIN p ON ST_Contains(mp.geom, p.geom)
+UNION ALL
+SELECT '#3437c' AS t, count(*) FROM mp INNER JOIN p ON ST_ContainsProperly(mp.geom, p.geom)
+UNION ALL
+SELECT '#3437d' AS t, count(*) FROM mp INNER JOIN p ON ST_Covers(mp.geom, p.geom)
+UNION ALL
+SELECT '#3437e' AS t, count(*) FROM mp INNER JOIN p ON ST_Within(p.geom, mp.geom);
-- Clean up
DELETE FROM spatial_ref_sys;
Modified: trunk/regress/tickets_expected
--- trunk/regress/tickets_expected 2016-02-24 16:25:57 UTC (rev 14685)
+++ trunk/regress/tickets_expected 2016-02-24 16:35:19 UTC (rev 14686)
@@ -283,3 +283,8 @@
#3399|1000|1000
#3399|100|100
ERROR: invalid KML representation
+#3437a|5
+#3437b|5
+#3437c|5
+#3437d|5
+#3437e|5
