[postgis-tickets] [PostGIS] #3464: ERROR: lwt_ChangeEdgeGeom could not construct face X, on the left of edge Y
trac at osgeo.org
Wed Feb 24 09:32:54 PST 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS Future
Component: topology | Version: trunk
Resolution: | Keywords: robustness
Comment (by strk):
So with r14690 I added the "side-location conflict" check, although with
different wording:
psql:bug3464.sql:21: ERROR: corrupted topology: new edge starts in face 1
and ends in face 0
The message, as usual, doesn't really contain enough info to know what's
going on, but the point is that the topology is found to be corrupted
because the edge-adding function first checks for edge/edge crossing and
finds none, but then finds that the edge started in a face and ended in
another, according to topology metadata.
Now I suspect the edge-crossing check is giving a false negative here,
because the topology isn't really invalid, but rather that component line
is crossing (almost in parallel) an existing topology edge.
As the edge-crossing check uses Relate, there might be a bug in GEOS
Relate, not finding a puntual intersection.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3464#comment:14>
