[postgis-tickets] r14691 - Fix invalid func, add a missing func
Regina Obe
lr at pcorp.us
Wed Feb 24 10:12:24 PST 2016
Author: robe
Date: 2016-02-24 10:12:24 -0800 (Wed, 24 Feb 2016)
New Revision: 14691
trunk/postgis/postgis_functions_search_path.sql
References #2485
Modified: trunk/postgis/postgis_functions_search_path.sql
--- trunk/postgis/postgis_functions_search_path.sql 2016-02-24 17:25:11 UTC (rev 14690)
+++ trunk/postgis/postgis_functions_search_path.sql 2016-02-24 18:12:24 UTC (rev 14691)
@@ -37,7 +37,8 @@
EXECUTE 'ALTER FUNCTION st_transform(geometry, integer) SET search_path=' || quote_ident(param_postgis_schema) || ';';
-- PostGIS raster funcs
+EXECUTE 'ALTER FUNCTION _raster_constraint_nodata_values(raster) SET search_path=' || quote_ident(param_postgis_schema) || ';';
+EXECUTE 'ALTER FUNCTION _raster_constraint_out_db(raster) SET search_path=' || quote_ident(param_postgis_schema) || ';';
EXECUTE 'ALTER FUNCTION _raster_constraint_pixel_types(raster) SET search_path=' || quote_ident(param_postgis_schema) || ';';
-EXECUTE 'ALTER FUNCTION _raster_constraint_info_regular_blocking(name,name,name) SET search_path=' || quote_ident(param_postgis_schema) || ';';
END;
\ No newline at end of file
