[postgis-tickets] r14693 - Add note per https://github.com/postgis/postgis/pull/14
Paul Ramsey
pramsey at cleverelephant.ca
Thu Feb 25 01:08:09 PST 2016
Author: pramsey
Date: 2016-02-25 01:08:09 -0800 (Thu, 25 Feb 2016)
New Revision: 14693
trunk/doc/reference_measure.xml
Modified: trunk/doc/reference_measure.xml
--- trunk/doc/reference_measure.xml 2016-02-25 08:56:42 UTC (rev 14692)
+++ trunk/doc/reference_measure.xml 2016-02-25 09:08:09 UTC (rev 14693)
@@ -2749,6 +2749,10 @@
<para>This function will return false if either geometry is invalid even if they are binary equal.</para>
</important>
+ <important>
+ <para>Do not call with a GEOMETRYCOLLECTION as an argument.</para>
+ </important>
<para>&sfs_compliant; s2.1.1.2</para>
<para>&sqlmm_compliant; SQL-MM 3: 5.1.24</para>
</refsection>
