[postgis-tickets] [PostGIS] #3429: upgrade from 2.1.3 to 2.2+ enters infinite loop
trac at osgeo.org
Fri Feb 26 00:21:32 PST 2016
Reporter: strk | Owner: dustymugs
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.2
Component: build/upgrade/install | Version: 2.2.x
Resolution: | Keywords:
Comment (by strk):
I had attached my proof-of-analisys patch, if dbaston wants to test it.
I had _not_ tried reverting r14697 but I believe it should be fine to do.
It should be also fine to revert r14694
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3429#comment:29>
