[postgis-tickets] r14700 - #3429, directly call set_handlers for allocator initialization
Paul Ramsey pramsey at cleverelephant.ca
Fri Feb 26 01:51:30 PST 2016
Author: pramsey
Date: 2016-02-26 01:51:29 -0800 (Fri, 26 Feb 2016)
New Revision: 14700
   trunk/raster/rt_pg/rtpostgis.c
Modified: trunk/raster/rt_pg/rtpostgis.c
--- trunk/raster/rt_pg/rtpostgis.c	2016-02-26 08:21:55 UTC (rev 14699)
+++ trunk/raster/rt_pg/rtpostgis.c	2016-02-26 09:51:29 UTC (rev 14700)
@@ -153,7 +153,99 @@
 #define RT_MSG_MAXLEN 256
+/*  Memory allocation / error reporting hooks                       */
+static void *
+rt_pg_alloc(size_t size)
+    void * result;
+    POSTGIS_RT_DEBUGF(5, "rt_pgalloc(%ld) called", (long int) size);
+    result = palloc(size);
+    return result;
+static void *
+rt_pg_realloc(void *mem, size_t size)
+    void * result;
+    POSTGIS_RT_DEBUGF(5, "rt_pg_realloc(%ld) called", (long int) size);
+    if (mem)
+        result = repalloc(mem, size);
+    else
+    return result;
+static void
+rt_pg_free(void *ptr)
+    POSTGIS_RT_DEBUG(5, "rt_pfree called");
+    pfree(ptr);
+static void rt_pg_error(const char *fmt, va_list ap)
+  __attribute__(( format(printf,1,0) ));
+static void
+rt_pg_error(const char *fmt, va_list ap)
+    char errmsg[RT_MSG_MAXLEN+1];
+    vsnprintf (errmsg, RT_MSG_MAXLEN, fmt, ap);
+    errmsg[RT_MSG_MAXLEN]='\0';
+    ereport(ERROR, (errmsg_internal("%s", errmsg)));
+static void rt_pg_notice(const char *fmt, va_list ap)
+static void
+rt_pg_notice(const char *fmt, va_list ap)
+    char msg[RT_MSG_MAXLEN+1];
+    vsnprintf (msg, RT_MSG_MAXLEN, fmt, ap);
+    msg[RT_MSG_MAXLEN]='\0';
+    ereport(NOTICE, (errmsg_internal("%s", msg)));
+static void rt_pg_debug(const char *fmt, va_list ap)
+static void
+rt_pg_debug(const char *fmt, va_list ap)
+    ereport(DEBUG1, (errmsg_internal("%s", msg)));
+void
+rt_init_allocators(void)
+    /* raster callback - install raster handlers */
+    rt_set_handlers(rt_pg_alloc, rt_pg_realloc, rt_pg_free, rt_pg_error,
+            rt_pg_debug, rt_pg_notice);
 /*  PostGIS raster GUCs                                             */
@@ -382,7 +474,7 @@
 	pg_install_lwgeom_handlers();
 	/* Install rtcore handlers */
-	rt_init_allocators();
+	rt_set_handlers(rt_pg_alloc, rt_pg_realloc, rt_pg_free, rt_pg_error, rt_pg_debug, rt_pg_notice);
 	/* Define custom GUC variables. */
 	if ( postgis_guc_find_option("postgis.gdal_datapath") )
@@ -464,93 +556,5 @@
 	pfree(boot_postgis_gdal_enabled_drivers);
-/*  Memory allocation / error reporting hooks                       */
-/*  TODO: reuse the ones in libpgcommon ?                           */
-static void *
-rt_pg_alloc(size_t size)
-    void * result;
-    POSTGIS_RT_DEBUGF(5, "rt_pgalloc(%ld) called", (long int) size);
-    result = palloc(size);
-    return result;
-static void *
-rt_pg_realloc(void *mem, size_t size)
-    void * result;
-    POSTGIS_RT_DEBUGF(5, "rt_pg_realloc(%ld) called", (long int) size);
-    if (mem)
-        result = repalloc(mem, size);
-    else
-    return result;
-static void
-rt_pg_free(void *ptr)
-    POSTGIS_RT_DEBUG(5, "rt_pfree called");
-    pfree(ptr);
-static void rt_pg_error(const char *fmt, va_list ap)
-  __attribute__(( format(printf,1,0) ));
-static void
-rt_pg_error(const char *fmt, va_list ap)
-    char errmsg[RT_MSG_MAXLEN+1];
-    vsnprintf (errmsg, RT_MSG_MAXLEN, fmt, ap);
-    errmsg[RT_MSG_MAXLEN]='\0';
-    ereport(ERROR, (errmsg_internal("%s", errmsg)));
-static void rt_pg_notice(const char *fmt, va_list ap)
-static void
-rt_pg_notice(const char *fmt, va_list ap)
-    char msg[RT_MSG_MAXLEN+1];
-    vsnprintf (msg, RT_MSG_MAXLEN, fmt, ap);
-    msg[RT_MSG_MAXLEN]='\0';
-    ereport(NOTICE, (errmsg_internal("%s", msg)));
-static void rt_pg_debug(const char *fmt, va_list ap)
-static void
-rt_pg_debug(const char *fmt, va_list ap)
-    ereport(DEBUG1, (errmsg_internal("%s", msg)));
-void
-rt_init_allocators(void)
-    /* raster callback - install raster handlers */
-    rt_set_handlers(rt_pg_alloc, rt_pg_realloc, rt_pg_free, rt_pg_error,
-            rt_pg_debug, rt_pg_notice);
