[postgis-tickets] r14703 - Expunge all trace of rt_init_allocators
Paul Ramsey
pramsey at cleverelephant.ca
Fri Feb 26 03:17:49 PST 2016
Author: pramsey
Date: 2016-02-26 03:17:49 -0800 (Fri, 26 Feb 2016)
New Revision: 14703
branches/2.2/raster/loader/raster2pgsql.c
branches/2.2/raster/rt_core/librtcore.h
branches/2.2/raster/rt_core/rt_context.c
branches/2.2/raster/rt_pg/rtpostgis.c
branches/2.2/raster/test/cunit/cu_tester.c
Modified: branches/2.2/raster/loader/raster2pgsql.c
--- branches/2.2/raster/loader/raster2pgsql.c 2016-02-26 10:02:57 UTC (rev 14702)
+++ branches/2.2/raster/loader/raster2pgsql.c 2016-02-26 11:17:49 UTC (rev 14703)
@@ -60,7 +60,8 @@
va_end(ap);
-void rt_init_allocators(void) {
+static void
+rt_init_allocators(void) {
rt_set_handlers(
default_rt_allocator,
default_rt_reallocator,
@@ -2285,6 +2286,9 @@
textdomain (PACKAGE);
#endif
+ /* Set up memory handling */
+ rt_init_allocators();
/* no args, show usage */
if (argc == 1) {
usage();
Modified: branches/2.2/raster/rt_core/librtcore.h
--- branches/2.2/raster/rt_core/librtcore.h 2016-02-26 10:02:57 UTC (rev 14702)
+++ branches/2.2/raster/rt_core/librtcore.h 2016-02-26 11:17:49 UTC (rev 14703)
@@ -40,9 +40,8 @@
* of non-PostGIS applications using rt_core.
* Programs using this library should set up the default memory managers and error
- * handlers by implementing an rt_init_allocators() function, which can be as
- * a wrapper around the rt_install_default_allocators() function if you want
- * no special handling for memory management and error reporting.
+ * handlers by calling rt_set_handlers() function, or the rt_install_default_allocators()
+ * function if you want no special handling for memory management and error reporting.
@@ -245,27 +244,12 @@
typedef void (*rt_message_handler)(const char* string, va_list ap)
__attribute__ (( format(printf,1,0) ));
- * Functions that must be implemented for the raster core function's caller
- * (for example: rt_pg functions, test functions, future loader/exporter)
- * Supply the memory management and error handling functions you want your
- * application to use
-extern void rt_init_allocators(void);
* Functions that may be used by the raster core function's caller
* Apply the default memory management (malloc() and free()) and error handlers.
- * Called inside rt_init_allocators() generally.
extern void rt_install_default_allocators(void);
Modified: branches/2.2/raster/rt_core/rt_context.c
--- branches/2.2/raster/rt_core/rt_context.c 2016-02-26 10:02:57 UTC (rev 14702)
+++ branches/2.2/raster/rt_core/rt_context.c 2016-02-26 11:17:49 UTC (rev 14703)
@@ -126,8 +126,7 @@
- * This function is normally called by rt_init_allocators when no special memory
- * management is needed. Useful in raster core testing and in the (future)
+ * Useful in raster core testing and in the (future)
* loader, when we need to use raster core functions but we don't have
* PostgreSQL backend behind. We must take care of memory by ourselves in those
* situations
@@ -145,7 +144,7 @@
- * This function is called by rt_init_allocators when the PostgreSQL backend is
+ * This function is called when the PostgreSQL backend is
* taking care of the memory and we want to use palloc family
void
Modified: branches/2.2/raster/rt_pg/rtpostgis.c
--- branches/2.2/raster/rt_pg/rtpostgis.c 2016-02-26 10:02:57 UTC (rev 14702)
+++ branches/2.2/raster/rt_pg/rtpostgis.c 2016-02-26 11:17:49 UTC (rev 14703)
@@ -414,6 +414,12 @@
char *env_postgis_enable_outdb_rasters = NULL;
bool boot_postgis_enable_outdb_rasters = false;
+ /* Install liblwgeom handlers */
+ pg_install_lwgeom_handlers();
+ /* Install rtcore handlers */
+ rt_set_handlers(rt_pg_alloc, rt_pg_realloc, rt_pg_free, rt_pg_error, rt_pg_debug, rt_pg_notice);
use POSTGIS_GDAL_ENABLED_DRIVERS to set the bootValue
of GUC postgis.gdal_enabled_drivers
@@ -461,14 +467,7 @@
boot_postgis_enable_outdb_rasters ? "TRUE" : "FALSE"
- /* Install liblwgeom handlers */
- pg_install_lwgeom_handlers();
- /* Install rtcore handlers */
- rt_set_handlers(rt_pg_alloc, rt_pg_realloc, rt_pg_free, rt_pg_error, rt_pg_debug, rt_pg_notice);
/* Define custom GUC variables. */
DefineCustomStringVariable(
"postgis.gdal_datapath", /* name */
"Path to GDAL data files.", /* short_desc */
Modified: branches/2.2/raster/test/cunit/cu_tester.c
--- branches/2.2/raster/test/cunit/cu_tester.c 2016-02-26 10:02:57 UTC (rev 14702)
+++ branches/2.2/raster/test/cunit/cu_tester.c 2016-02-26 11:17:49 UTC (rev 14703)
@@ -239,14 +239,3 @@
return band;
- rt_set_handlers(
- default_rt_allocator,
- default_rt_reallocator,
- default_rt_deallocator,
- cu_error_reporter,
- default_rt_info_handler,
- default_rt_warning_handler
