[postgis-tickets] [PostGIS] #3076: Unqualified function calls break postgres_fdw compatibiliy
trac at osgeo.org
Fri Feb 26 16:21:20 PST 2016
Reporter: fphilipe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: postgis | Version: 2.1.x
Resolution: | Keywords: restore
Changes (by robe):
* keywords: => restore
Comment:
I think I have a plan. This is a mockup of it,
https://trac.osgeo.org/postgis/browser/trunk/postgis/postgis_functions_search_path.sql
but once I test this I'll be braver and just have it generate a script to
do this for all functions (messing with strks' perl scripts to generate
this additional script (one for postgis proper and one for raster).
For 2.3, we can fold this in the create extension, update extension
process. For older, I'm just going to have it as a stand-alone script
with an FAQ that people should run the script after every install and
upgrade to be able to easily restore their backups and also make there fdw
and materialized views work.
Sadly there is a downside. Downside being I can't have the search path
change in the ALTER EXTENSION .. SCHEMA change. Unless I introduce event
triggers (which someone in code-sprint suggested) which pramsey at
codesprint gave a sour face too.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3076#comment:13>
