[postgis-tickets] [PostGIS] #3479: ST_ClusterKMeans hangs with one row (was: ST_ClusterKMeans hangs)
PostGIS trac at osgeo.org
Sat Feb 27 08:14:04 PST 2016
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.3.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> I think it's memory exhaustion.  My postgres server just hangs.
> -- generate sample parcel test
> -- has 8 parcels, works fine
> CREATE TABLE parcels AS
> SELECT row_number() OVER() AS parcel_id,
>     ST_Subdivide(ST_Buffer('LINESTRING(0 100, 100 200)'::geometry,50,
> 'endcap=flat'),8) As geom;
> -- now try to do a ST_ClusterKMeans
> SELECT ST_ClusterKMeans(geom,3) over () AS cid, geom
> FROM parcels;
> My server just hangs not sure what it's doing.  I had to kill all my
> postgres processes.
New description:
 My postgres server just hangs. Simpler
 DROP TABLE IF EXISTS parcels;
 SELECT 1 AS parcel_id,
     ST_MakeEnvelope(0,0,200,200) As geom;
 FROM parcels;
 postgres processes.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3479#comment:1>
